Duratracs if you see snow/ice
MTR Kevlars for everything else (esp if you are going to see mud/rocks/trail time).
Toyo's are "ok"...![]()
I have MTR Kevlars on my jeep and they do not stop in the rain, kinda scary actually.
Anyone have methods standard with 20" ?
I was asking real world measurements because alot of the time its more or less.
so you want someone to measure their tires?
I'm trying to understand what your point is here?With the Toyo being taller, wider, deeper lugs and more ply of course it is going to weigh more, its more tire.
I'm not sure on the deeper lugs other then the side lugs. The Duratracs have some pretty deep lugs.
With method wheels and Duratracs you'll be at 85lbs per corner. Only 2.5 lbs more then the Toyo's without wheels.
Just go the manufacturers site. They have a spec tab which lists the actual real world measurements. There could be a difference once mounted under the load of a truck but i'm sure it would be the same difference for both tires.
I'm not sure how to make it simple for you but I will try. The Toyo is a bigger tire then the Duratrac, it has more material in its construction so it is going to be heavier. Yes it has much deeper lugs more ply's taller and wider, more material thus heavier, not a bad thing unless your planning on racing Corvettes.
Goodyear Wrangler DuraTracYeah, I found out the other tires I'm interested real height on some random jeep forums, but only could find 33" duratrac measurements & no 35" ones. Seems like they run small like the stockers.
