Tire Weights
All The Way
Lockport, NY
How have these been working for you? I've avoided retreads after some experience with the many years ago.
Shit, just saw this. I ran them at HITH and they held up great. Right now they are off the truck for the winter. (trying to burn up a set of BFG's)
Glo
You may very well be right. When I was trying to find different styles of 35/37in tires I came across the 'Baja T/A' (the 'non projects') on Tire Rack and that was the advertised weight. I just tried to verify and that tire doesn't come up anymore - they now are showing the 'project' tread pattern Baja but the advertised weights are lower than they should be.
Per Goodrich's website:
49244 35x12.50R17/C 111 T = 63.6lbs
89885 37x12.50R17/D 124 T = 76.8lbs
Raptizzle measured his Baja DOT in at 75lbs http://www.fordraptorforum.com/f25/weighing-37-grabber-red-label-v-37-bfg-baja-t-dot-14229/
treypal
Lord of the Raptors
Riviera TX
Don't think Kevlar does much for sharp rocks - not sure about it - just don't think Kevlar vests do much for knifes.
Then why are they on 75% of the trophy trucks out there?
They are THE tire for dirt. The problem is they are a unitasker.
I would never run a tire that weighs 20lbs more than another option. The drawbacks far outweigh the benefits.
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
Oh I have some 35" project treads at work and happen to have a big scale. I'll weigh one tomorrow.
Jarrett H
Baja ta's are designed to do just that. They are probably the most robust rugged non military tire made. Take a look at one sometime....
Glo
I think you mistook my response as a put down for the Bajas - I am not - still planning on getting a set as soon as I can find some that are reasonably priced. Until you mentioned it - I hadn't registered that BFG is using Kevlar now too.
I sat at a campfire in Saline Valley with a BFG rep a few years ago that responded to Goodyears MTR with Kevlar that had just been released as " just marketing" - and it somehow stuck with me. Never saw anything about BGF using Kevlar - only saw a web snippet saying that Goodyear has Dupont Kevlar exclusivity for tires - but then that might be outdated.
As to your question on why 75% of the Trophy Truck field is running BFG - I don't have any insight on that - but I'll be happy to try...maybe because non of the other main tire brands find Trophy Truck racing important enough and Michelin is pumping all of BFG's advertising budget into a not highly contested national racing series that is closest to their core target market and heavily support the majority of racing teams?
I totally agree with you on not wanting to run a 20lbs heavier tire - I think I made my point of view clear in my previous posts...
Looking forward finding out what you projects weigh in at!
I have and I am continuing to look into all different tire options...certainly will get to drive some soon!
Nick@Apollo-Optics
For folks looking for a lighter, comparable tire to the the Toyo MT, the Cooper Discoverer STT weighs 78lbs in 35x12.50x17 and the 37x12.50x17 weighs 84lbs.
dkfc13
HPA Systems LLC.
SE Michigan
Baja T/A tire differences
