i actually like them. ima have to keep them in mind.
Same here. I like em too. Good luck BD, be sure to post some pics after you mount em!!
They look good. I'd get a bump up to the middle perch if I were you. Definitely before April. Rock n Roll Offroad does it in about 2-3 hours for $250 out the door.
We will see how these do. I think one of them took a lot of weight but the way these guy's balanced them don't make sense to me. Weights on the inside and outside of the wheel 180 degrees apart????? It drives good.
BDRAG
When ever the weight exceeds 4oz., it should be split to each side of wheel otherwise
the weights would not be balanced equally to the width of wheel.
If tire takes excessive weight to balance, some guys will break the bead,
rotate tire 180* opposite to the excessive weight, then, rebalance.
I've seen this method reduce an '8+ oz. balance', down to 2 oz..
If you want to "go all out" . . you could get a "road-force-balance".
It's more expensive and as the tire wears, it will probably need to be rebalance anyway.
Some tires are cheaper because . . . . they're cheap . . . and the mfg specs are not "as tight" as others.
Tires in picture look pretty gnarly.
Good info - for those of us that do not have a desert to baja in -
-thanks for sharing.
Those look good bd! Are they noisy?
