Tire pressure question
MJslasherADMIN
I run 35 all around. Both of my Gen 2 trucks had insane pressure in all tires when I drove them off. Tires with 50 and 60 psi. PDI techs are going to get someone killed letting them drive off like that.
MJslasherADMIN
Its cold out right now. So my pressures are lower than normal. Generally 35. IMG_0671.jpg
Mr. Elite
Elgin,IL
I have a 2011 super crew... I run 38psi at all corners now for mostly street use and of course a lil bit of off-road playing as well... But my question is can run 35 or 36psi all around safely!? I was a lil more contact patch on the ground to hook up, and would like to soften the ride a lil on and off road if possible..??
Can I get some input on this from any1 who has tried it personally plz??
Ruri
SoCal
When you guys state the PSI you run; is it cold tire temp PSI or Warm tire temp?
Because I air up at Costco with nitrogen and the PSI will fluctuate a few from cold to hot
castine917
Caledonia, Mi.
Should be checked cold. Hot temps will be higher. Usually a few degrees.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=147
Below is copy and paste from link with regards to air. Nitrogen will fluctuate even less.
Air Pressure: When & How to Set
"Check and adjust first thing in the morning...before rising ambient temperatures, the sun's radiant heat or even driving short distances temporarily warms the tires."
Maintenance Tips to Increase Tire Performance, Life and Durability
Check and Adjust First Thing In The Morning. Set according to the vehicle manufacturer's cold tire pressure(s) recommended on the vehicle's tire placard or in its owner's manual. This must be done before rising ambient temperatures, the sun's radiant heat or even driving short distances temporarily warms the tires.
Accommodating Variables
Indoor-to-outdoor Temperature Variation. Significant differences between the conditions tire pressures are set (the warmth of an attached garage, heated garage or service shop) and in which the vehicle will be driven (winter's subfreezing temperatures) requires inflating tires 1 psi higher than recommended on the placard for every 10° F difference in temperature between interior and exterior temperatures.
Afternoon Ambient Temperature Increase.* Set 2 psi above vehicle manufacturer's cold inflation recommendations when installing new tires or if the vehicle has been parked in the shade for a few hours.
Tire Heat Generated While Being Driven (or at speeds of less than 45 mph).* Set 4 psi above vehicle manufacturer's cold inflation recommendations.
Heat Generated While Being Driven Extensively (or at sustained speeds greater than 45 mph).* Set 6 psi above vehicle manufacturer's cold inflation recommendations.
Do Not Release Hot Tire Pressure if any of these variables could be the cause of measured tire pressure exceeding the maximum psi branded on the tire's sidewall by the 2, 4 or 6 psi indicated above for the various conditions. This temporary pressure increase is expected and designed into the tire's capabilities.
Note: Tires on a parked vehicle exposed to direct sunlight will appear overinflated due to the heat absorbed from the radiant energy of the sun. Pressures cannot be accurately set on these tires until all have stabilized in the shade.
dewalt
Truck weighs less than 2000 pounds per tire. Go to inflation chart for 2000 pounds on a d rated 315/70/r17 and you will have minimum pressure. Adjust up from there for handle or load
