The Tune by SVC
MTF
Celebration, Florida
Gave up already... ordered a whipple kit!
As to SVC, not sure what happened, used to be REALLY quick on reply, but not anymore in my case.
oplersx, I have to say, you need to fix your current situation with pinging.
Throwing a SC on without fixing what's happening now while NA, you risk blowing up your engine with all the extra boost.
Plus all issues you have now will only be increased 10X over after going SC.
oplersx
British Columbia
Hi Jeff,
Replied your email on 29th Nov. Just emailed again. Please check.
Thanks,
Bing
Bing,
I have not received an email from you after our last follow up sending the tune with timing very unadvanced. The problem were having is strange because tunes don't just expire after a year and all of a sudden start pinging unless there is some sort of mechinal issue or change. Your tune is the same tune a large majority of raptor owners are running daily with no issues at all.
Jeff
svc
svc
Worldwide
Hi Jeff,
Thanks,
Bing
I will check now, my email was down Friday- Tuesday so that could have been the issue .
Jeff
oplersx
British Columbia
oplersx, I have say you need to fix your current situation with pinging.
Back on stock tune now, no knock.
I also paid a local shop did a diagnose, I posted the memo earlier, too much timing, no mechanical issue. I will have the shop do the SC install, maybe they can double check on the engine while installing SC?
MTF
I know, but something is going wrong somewhere, the timing is advanced with the SC Tune also so you'll probably have the same issues.
Just give Jeff @ SVC a chance to help you, I know it's frustrating when things don't go right.
You are the only one having this issue, and for them to send you a Tune without timing advance is kind of worthless.
oplersx
British Columbia
I was told, mechanically, the knocks can be caused by bad injectors, plugs or sensors. And then, the tune. Don't know how true it is. But with the SC kit, injector and plug are going to be replaced. Sensor tested OK... so hope it will be a smooth install:baby: If it's not, then that's life :slap:
Have to decide on which whipple tune to go with.
Riddick
Hey Jeff,
Is y'alls emails down again or something? Have emailed you a couple of times and haven't heard anything.
Thanks,
Lee
