The FRF Shock Shootout! All pre event details and discussion here
Status
Not open for further replies.
Wilson
South Dakota
I still say it dose not have to be a raptor. any cheep truck as long as all 3 or 4 are the same make model weight tire and so on this is going to be hard to keep equal. I would say one truck change the shocks out each time but. every thing must be considered. maybe we will get lucky and svt will donate a truck to use never hurts to ask.
onesickpuppy
Ruler of the Earth
You should be able to use the nanny on the key to limit the speed???
Also, the designated drivers need to be instructed to drive the same lines on the course, where typically a driver will tend to hunt for a better/best line. We will need consistancy for sure to make it fair for all shocks and vendors.
J good job on keeping this fair!!! Hang in there.... and we thought this would be an easy task to pull off. The dyno should be the most consistant and controlled test.
Lou
pirate air
will plunder your booty
That's not a bad idea. Lots will depend on the loaner truck, for sure.
I plan on doing something similar with mine and possibly re valving the compresion because I feel the current aggressiveness of the bumps maybe hurting the performance of my ICON set up more than helping, but the/some protection is still needed for the harder hits. For stock it was fine but too much now with the addition of the 3.0s. If I feel the change works to an advantage I'll do a write up and maybe something similar could be done for the testing (obviously IF the test truck has the same bump kit).
Bleeding the bumps to zero for the test wouldn't make me warm and fuzzy as the truck owner. Id rather have stock bump stops and a frame brace kit. If a hard hit is taken by accident, the bled down bump will add zero resistance but just a place for all the remaining force to slam into. At least the factory rubber stop gives gradually increasing resistance.
Wilson
South Dakota
I like going balls out across the field at 90. I have stock shocks the only way I would feel that any shock is better is if I drove a truck with a different set up. I would suggest the shock boy's get some trucks ready to test drive at some major events. to me that is the true test. but I still like seeing it on paper if I was about to dish out the coin.
Hockster
My 45ft Bluewater Party
Winchester, Va
Nah, nothing so complicated. I just plan to use a remote operated Tazer.
It needs to be a cocktazer one of them small winnie doggies ones that will fit elsewhere if ya know what i mean!!! ha ha ha A small jolt to the neck might now work on some of these guys
Raptizzle
FYT
Southern CA
Not you fat jesus
BIRDMAN
Birdministrator
Boston
Right on pirate. If the bumps are set at 0psi, then you would be asking the bump stop kit to do something it wasn't designed to do. Actually, not entirely true, the bump pad would do what it's designed to do: not deform. No good.
This would not accomplish the main goal of keeping the donor truck safe, isn't that the point? Sure, the shock performance won't be affected by an aftermarket bump, but that's a double edged sword.
I think like BigJ says, we don't have a donor truck yet and can't be picky. Ideally, in my mind, the donor truck should have a RPG Stage 1 kit or equivalent. Where does RPG stand on this? SDHQ? Outlaw? Could we approach them to provide a Stage 1 (or equivalent) kit to borrow for testing? Free promotion and you'll get your parts back guys...or maybe the kit can find a new home on the donor truck at a discount.
Then we just need a stock Raptor in the Southern California area...bolt on the "Stage 1" (sorry to use RPG branding) and off we go with 3 great sets of 3.0 Raptor shocks. I would allow such a scenario with my truck, sounds very solid.
Wilson
South Dakota
get them back the donner will probably buy some if he is at all interested. they will be used so a discount should be considered.
Status
