Terrain Management troubleshooting
Kevin LaChapelle
Redmond, WA
Recently my 2019 started throwing the error on the display of “Terrain Management Not Available” whenever I tried to select a driving mode. I have spent a ridiculous amount of time understanding the Terrain Management System (TMS) by trial and error, diagnostic tools, and the help of our forum member FordTechOne. I found the information online on the TMS to be lacking to say the least and frankly what I did find wasn’t fully accurate. So, in the hopes of helping anyone that experiences this issue after me a way to quickly understand what is going on and how to resolve it.
The TMS is made up of several components: (All part numbers are for my 2019)
· Vehicle Dynamics Module (VDM) – KL3V-18B008-AK (to find it online search for just 18B008)
o Powered by fuse 14 in the fuse box near the battery​
· Ride Height Sensor
o Front Left - 3C097​
o Front Right - 3C097​
· Live Valve Solenoid
o Front Left - KL3Z-18B082-D​
o Front Right - KL3Z-18B082-C​
o Rear Left - KL3Z-18B084-D​
o Rear Right - KL3Z-18B084-C​
In my journey trying to understand what was happening with my 2019 I was challenged by the fact that there were no codes visible in ForScan. I went and purchased the same diagnostic computer Ford dealers use (VCM3) and the IDS software. This afforded me more diagnostic tests which led me to seeing that the VDM wasn’t reachable for testing. This highlights a key difference between ForScan and the Ford IDS software. ForScan will only show you the modules that are live on the network, while IDS will show you the modules that are not active on the network. In this case when there was limited information available, ForScan didn’t help me initially. Had I known that the VDM is the key module for Terrain Management, having it not show up in ForScan would have helped me focus the investigation.
If you have Terrain Management issues, use ForScan to look for the VDM module. If it doesn’t show up, check Fuse 14 in the fuse box by the battery (The manual says that fuse 14 is not used, which caused me to waste time trying to find the power source to the VDM). If it does show up, look for any codes that it may have produced. I have included below the chart of codes that the VDM may throw and what they mean. If the fuse is intact you can use the wiring diagrams and connector pinouts I have placed on the following link (Link to docs) to help trace the circuits to find the issue.
One note: The VDM and the codes listed are used across a number of Ford vehicles. Not all codes are relevant to the Raptor. For example, the Raptor only has ride height sensors on the front wheels.
I truly hope this helps as I would have loved to have this post months ago.
Symptom Chart: Vehicle Dynamic Suspension
(Cond)ition and Possible Sources (PS)
Cond: A module does not respond to the diagnostic scan tool
PS: Fuse, Wiring, Terminals or Connectors, VDM concern
Cond: Message center displays, DRIVE CONTROL MALFUNCTION SERVICE REQUIRED
PS: DTCs Present in the VDM
Cond: Rough or harsh ride
PS: Vehicle dynamic suspension system disabled
VDM DTC Chart
DTC Description
C110C:11 Left Front Damper Solenoid: Circuit Shorted to Ground
C110C:12 Left Front Damper Solenoid: Circuit Shorted to Battery
C110C:13 Left Front Damper Solenoid: Circuit Open
C110D:11 Right Front Damper Solenoid: Circuit Shorted to Ground
C110D:12 Right Front Damper Solenoid: Circuit Shorted to Battery
C110D:13 Right Front Damper Solenoid: Circuit Open
C110E:11 Left Rear Damper Solenoid: Circuit Shorted to Ground
C110E:12 Left Rear Damper Solenoid: Circuit Shorted to Battery
C110E:13 Left Rear Damper Solenoid: Circuit Open
C110F:11 Right Rear Damper Solenoid: Circuit Shorted to Ground
C110F:12 Right Rear Damper Solenoid: Circuit Shorted to Battery
C110F:13 Right Rear Damper Solenoid: Circuit Open
C1124:55 Height Sensor(s): Not Configured
C1124:56 Height Sensor(s): Invalid or Incompatible Configuration
C1A03:11 Left Front Height Sensor: Circuit Shorted to Ground
C1A03:12 Left Front Height Sensor: Circuit Shorted to Battery
C1A03:64 Left Front Height Sensor: Signal Plausibility Failure
C1A04:11 Right Front Height Sensor: Circuit Shorted to Ground
C1A04:12 Right Front Height Sensor: Circuit Shorted to Battery
C1A04:64 Right Front Height Sensor: Signal Plausibility Failure
C1A05:11 Left Rear Height Sensor: Circuit Shorted to Ground
C1A05:12 Left Rear Height Sensor: Circuit Shorted to Battery
C1A05:64 Left Rear Height Sensor: Signal Plausibility Failure
C1A06:11 Right Rear Height Sensor: Circuit Shorted to Ground
C1A06:12 Right Rear Height Sensor: Circuit Shorted to Battery
C1A06:64 Right Rear Height Sensor: Signal Plausibility Failure
P1758:19 Pressure Solenoid Control System Incorrect Current: Circuit Current Above Threshold
U0100:87 Lost Communication with ECM / PCM "A": Missing Message
U0121:87 Lost Communication with Anti-Lock Brake System (ABS) Control Module: Missing Message
U0131:87 Lost Communication with Power Steering Control Module: Missing Message
U0140:87 Lost Communication with Body Control Module: Missing Message
U0151:87 Lost Communication with Restraints Control Module: Missing Message
U0155:87 Lost Communication with Instrument Panel Cluster (IPC) Control Module: Missing Message
U0253:87 Lost Communication with Accessory Protocol Interface Module: Missing Message
U0401:00 Invalid Data Received from ECM / PCM "A": No Sub Type Information
U0415:00 Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A: No Sub Type Information
U0420:00 Invalid Data Received from Power Steering Control Module A: No Sub Type Information
U0422:00 Invalid Data Received from Body Control Module: No Sub Type Information
U0452:00 Invalid Data Received from Restraints Control Module: No Sub Type Information
U1000:00 Solid State Driver Protection Active-Driver Disabled: No Sub Type Information
U200D:11 Control Module Output Power A: Circuit Short to Ground
U200D:12 Control Module Output Power A: Circuit Short to Battery
U200E:11 Control Module Output Power B: Circuit Short to Ground
U200E:12 Control Module Output Power B: Circuit Short to Battery
U2024:51 Control Module Cal-Config Data: Not Programmed
U2100:00 Initial Configuration Not Complete: No Sub Type Information
U2200:00 Control Module Configuration Memory Corrupt: No Sub Type Information
U3000:04 Control Module: System Internal Failure
U3000:49 Control Module: Internal Electronic Failure
U3003:16 Battery Voltage: Circuit Voltage Below Threshold
U3003:17 Battery Voltage: Circuit Voltage Above Threshold
Cobraman044
Toledo, OH
Big thank you for this post!!!! I was getting the terrain management not available error. I was ready to take it to the dealer. Would have been embarrassed when they found I used an fuse tap on fuse 14 for my morimoto lights start up. Since it was suppose to be not used. Removed tap and it works. Fuses were good. Maybe bad tap but I will troubleshoot that later.
Thanks again
troyking
florida
TWO DEALERS FOUR DAYS NO ONE CAN FIX TM...WENT TO LOOK AT #14 AND THERE WAS NO FUSE!! I PUT THE ONE FROM 15 INTO 14 AND IT WORKED...QUESTION;ITS 15 AMP, IS THIS CORRECT??
InigoMG
Los Cabos
Hi, I lifted my 2019 Raptor 6 inches and Im getting the TMS Not Available. Already checked for the fuse 14 and that doesn’t fix the issue. Any other known fix?
GordoJay
Colorado
If you lifted a Raptor 6 inches, God knows what you screwed up. Good luck. Did you look for the TMS to show up in Forscan?
John Rathjen
SWATDOC
USA
I’m going through this right now on my ‘19. Rear suspension was done 2 years ago. Front suspension done about 9 months ago. LV shocks removed and have been running the plug in bypass module from RPG the past 2 years. Never any problems until last week.
My modes will work just fine when I drive my truck for the first time of the day. Will last about 10-15 minutes in sport mode, then the truck throws it back into normal mode by itself. Then if I try to change the mode at that point I get the message “terrain mode unavailable “
So since it will work briefly when I first run the truck for the day, I doubt it’s a fuse issue. Truck has been at the dealer for 2 days now with no word
