SVC Adjustable Bump System
TXRPTOR37
Any type of deal when you buy the ABS with the deavers?
Also, do you recommend +2 or +3 springs for a screw? I want to be able to put more than 200lbs. In the bed without it going nose up.
Yukon Joe
Trafford, PA
Ironside,
To be honest the two bumps perfrom nearly identical, the only reason the foxes are listed as more is because Fox choose to retail them at a higher price then king. Both bumps get the job done and I can guarantee if you rode in a truck with the kings and then the foxes it would feel the same. You essentially pay for color or brand loyalty when it comes to the bumps
-Jeff
What pressure does king run verses Fox?
Yukon Joe
www.RUNRAPTORRUN.com
svc
svc
Worldwide
Depending on if the customer has a 3.0 or not. The standard I send both sets out at is between 100-110 psi . If they have leafs and 3.0 it ranges between 75-100 for either brand
-Jeff
Gsteve
I haven't watched the video yet , but does the bumper make any contact when in the comfort mode ? Im trying to find something to get rid of that stutter rubbery feel the rear has over cracks and bumps. So far the only answer over gotten was to change rear springs.
JayneCobb
San Pedro, CA
If you are running stock shocks and leafs then you're not going to get rid of the stutter. New leafs will mitigate it a little but it will still be there. The only way to get rid of the stutter that I know of would be to get a set of 3.0s for the rear. Comfort mod on the ABS is so that the bumps don't make contact every time you hit a bump in daily driving.
Gsteve
ahhh ok... thanks! I would have hated to have tossed 2,000 into springs and still had that annoying stutter. Canadian $$ shipping , install = 2,000
englishrodder
Fort Collins CO
Just wanted to say great service from Jeff at SVC, there was a small shipping issue and he fixed it quickly.
Also ordered a set of Deavers from them, now to fit them at the weekend.....
