SVC Adjustable Bump System
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
yO .. . your old bump stop is showing
Haha yes I know
That^
See above
---------- Post added at 08:59 PM ---------- Previous post was at 08:57 PM ----------
That's actually impossible as the design of the frame support will not allow the stock bump stop to be reinstalled. Unless you shave the little fingers off the stock bumpstop that go into the frame
Yea it's a long story, but here's what happened... Had the ABS and a set of deaver +3 shipped, UPS lost one of the deavers, I'm going on a trip his weekend to play so no time to get another deaver, so stock leafs it is this time around, stock leafs require some additional hardware from SVC to attach striker plate, which I didn't have, because deavers were ordered. So because I'm short on time, and to save time, I installed the ABS and waited while Jeff overnighted the rest of the hardware that I now needed because stock leafs. So in-between that time I reinstalled the OEM's bump stop by cutting the "fingers" off, putting some duct tape on the mount so as not to scratch powder coat, and bolting it back on through the ABS hole.
stupid question ... the bolts (3) head to the bump canister is unique. I assume you need a special socket? Is this socket provided in the kit or one would have to buy one?
And I assume tig welded is stronger? Also does anyone have a the weight of this kit? I know the RPG kit weighed in at 100 pounds while the icon kit is 70 pounds.
The bolts on the bump can are just standard 12 point sockets/wrenches.
Tig vs. Mig..... That's a whole nother discussion that could take an hour. Main advantage of tig is cleaner, more precise welds. TIG welds generally are more ductile (less brittle) than MIG. This is because TIG creates a larger HAZ (heat affected zone) than MIG (that's the blued area going away from the weld joint). TIG also tends to mix the filler material with the base material better than MIG. It's also ALOT more time consuming, hence why higher costs in having parts tig'd. Overall strength between two good Mig vs. Tig welds would be very close.
I believe my shipped weight for my ABS was like 70-80 pounds, I think, I can't remember.
---------- Post added at 10:18 PM ---------- Previous post was at 10:05 PM ----------
I assume a 6 point socket would still work?
I wouldn't recommend it. Not at the torque ratings required.
Deleted member 12951
Guest
That's funny. Earlier today when I saw those pictures, I thought the same thing about the OEM bumpstop but I kept looking at it and kept saying to myself, naw that can't be, it's got to be something else. Even grabbed my OEM bumpstop laying around to see if it matched but mine looked a little longer.
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
That's what they all say...:okay2:
Yea just figured since I didnt have the strike plates installed yet, it would be easy enough to just reinstall the Oem bumps to be safe.
Raptor911
Ashburn, VA
Someone should make a front bumper with a clear coat because the raw metal is just plain sexy.
