SVC 1.5" Collars - Impressions
cdiddy4224
cdiddy4224
USA
Thanks for the info. I don't want to go into forscan without knowing the correct modules or value that i should be modifying. Hopefully someone will have info on that soon.
flyingrick13
LV, NV
I just did the RPG 2.25 to my Gen 3 35 truck. The ride is still smooth as butter with now 37s! Also is spot on level. Make sure the shop resets the live valves though! That is a huge step that needs to be done.
cdiddy4224
cdiddy4224
USA
Any idea if you shop used the reset method used for the Gen 2s?
cdiddy4224
cdiddy4224
USA
They did. Software wise, nothing has changed for the reset. The reset recenters the solenoids for a new 0.
Well I just tried it through forscan and the ride calibration isn’t there. You can see you current settings but nothing to let you recalibrate
cdiddy4224
cdiddy4224
USA
I just posted over in the forscan Gen 3 thread that we can now adjust our ride height using forscan
