cdiddy4224
Thanks for the info. I don't want to go into forscan without knowing the correct modules or value that i should be modifying. Hopefully someone will have info on that soon.
Any idea if you shop used the reset method used for the Gen 2s?I just did the RPG 2.25 to my Gen 3 35 truck. The ride is still smooth as butter with now 37s! Also is spot on level. Make sure the shop resets the live valves though! That is a huge step that needs to be done.
Clearance. Approach angle. Wheel fitment. Tire size. Ride quality.I do not get the appeal of raising the front end.
They did. Software wise, nothing has changed for the reset. The reset recenters the solenoids for a new 0.Any idea if you shop used the reset method used for the Gen 2s?
Well I just tried it through forscan and the ride calibration isn’t there. You can see you current settings but nothing to let you recalibrateThey did. Software wise, nothing has changed for the reset. The reset recenters the solenoids for a new 0.
Is yours a Gen3? I believe it's there for the Gen2.Well I just tried it through forscan and the ride calibration isn’t there. You can see you current settings but nothing to let you recalibrate
Correct, only for Gen 2s. Currently only Ford can recalibrate Gen 3s with FDRSIs yours a Gen3? I believe it's there for the Gen2.
