Sunroof Shade won't stay shut
K223
Florida
I’d be shocked if they completely revamped the whole pano roof system. Would hope improvements were made however.
FL4x4
Orlando, FL
Having problem where the sunroof shade closes and just as it gets to the completely closed position (it crosses the headliner) it retracts back to the midpoint. Has anyone experienced this and is there an easy fix or is it off the dealer? TIA
Try this if you have not already ...
Sunroof Reset 2019 F-150 Raptor
  • 1. Close all doors, start truck.
  • 2. Open the Sunshade to the half way (1st stop) position
  • 3. Make sure that the Sunroof is Closed
  • 4. Press Sunroof Close Button once (Press and Release)
  • 5. Press and HOLD Sunroof Close Button until sunroof and sunshade stop moving. During this process, the following will happen:
    • Sunroof will go into vent position and stop
    • Sunshade will close and then open all the way and stop
  • 6. Once the Sunshade has opened all the way and stopped - Release the Close Button
  • 7. Press and HOLD the Close Button again:
    • Sunroof will then close, and cycle all the way open and then close.
    • The sunshade will then Close.
  • 8. When shade closes, release the Close Button.
  • 9. Reset is done. Test operation.
