can you direct me to the procedure? I basically just disassembled, reassembled, torqued and left it at that.Did the issue start after hub replacement? There a specific procedure to follow when replacing a hub or IWE.
I did not change the vacuum hub side
The issue started about a month after I replaced the wheel hub. I did not replace the IWE at the same time, but based on one of the responses, started researching IWE issues. and found folks describing "playing cards in a bicycle wheel" and that is a better description than my paper crumpling reference.
I've just ordered an IWE solenoid and check valve from AMAZON cheap and easy
It may be likely that the vacuum hub it's self is no good due to heat/etc. when the wheel bearing failed. I had to drive on it for 6 weeks while ford tried to locate one - eventually gave up and ordered from Amazon
