touchdowntexas
- Joined
- Jul 9, 2012
- Posts
- 11
- Reaction score
- 4
Remove the two nuts, raise the engine, and then remove the three bolts. Were you able to get the bolts out already?
If you followed the instructions it should be coming up. Stock manifolds are off? Air box and intake disconnected?
Where are you jacking up at?
Already got the bolts out. Stock manifolds are still on. Air box and intake are disconnected. I am jacking under the oil pan with some wood.
How much lift did you get on the engine? I added more blocks to get some more lift, and have gotten it up probably 1/4". How much do I need?
