SnoBall Preparations?
joekai
Chippewa Lake OH
Got my little project of rear ambers completed to day, I like em!
---------- Post added at 01:15 AM ---------- Previous post was at 01:06 AM ----------
Also got the new Rigid E2 hyper spot all hooked up!
That hyperspot is sick!!! Gotta get me one!
blockdoc
Lexington, KY
So far today:
Mid perch & front end alignment
Rear bumper & wired up Duallys
Wired up HIDs on hood mounts
WSI fold back light bar
Vortex flaps
Gonna go work on wiring the Rigids & Whelens, and put in the WSI bed rack.
---------- Post added at 05:26 PM ---------- Previous post was at 05:22 PM ----------
Big hats off to Warn!
I called them & explained what happened, and that I need the winch in a couple days. I thought I would have to buy another and try to sell this one as a refurb. Warn is sending me a new housing overnight, so the winch will be on tomorrow.
Excellent customer service; glad I went with the Warn.
Ms. MI Raptor
FRF Lady
FRF Lady
Marquette, MI
I'm notorious for volunteering tall men to help... In fact, Mandy, my brother in law will be there and he can help load the bed/ tie stuff down... Just tell him i told you so.
Thanks for volunteering the manpower! Still no news on my truck so keeping my fingers and toes crossed!
OrangeAddict
Raleigh, NC
So far today:
Vortex flaps
Nice Pics Doc.
Couple of Questions, do you have the front camera on that? If so I want to see the look out it with that bumper.
Second, Is it me or is the back bumper sagging a bit?
blockdoc
Lexington, KY
I do have the front camera. I'll get a pic for ya, and you can see it in person in a couple days.
The bumper doesn't really appear to sag in person, but it sure looks like that in the pics. I might end up having to put a spacer on the bottom anchor points to raise it up in back.
On your Lamphus, do ten suction cups make it point way up or way down? I didn't want to permanently mount mine, and it points either up or down with those suction cups. Right now it points at my tailgate.
BramageDained
I still need to make a bracket to mount my lights and I have an appointment for an oil change on Wednesday and that's it.
I... already have the truck loaded up and my clothes packed.
OrangeAddict
Raleigh, NC
Yeah That is the reason I did not really like the mount that came with the Lamphus It seemed to be made for an angled window. I did leave the mount on the light since it helped keep the light spaced from the back window to prevent breaking a window.
The quick mount I did isn't what I would call permanent BTW. It is just a couple of sheet metal screws. Depending on how this works and when I get a light bar rack I will likely go with a different solution at some point.
No Pic necessary I will check it out in person. You brining any liquid warmer?
I was thinking of bringing one of these if your interested.
Crikk
FRF Lady
FRF Lady
Crystal lake il
I'm freakin out!! My truck seems to be fallen victim to problems this week. HELP!!!
I was hearing a noise like if I had a sticker on my tire treads, so I went back home and looked all the tires and thought I saw something weird on the inside of the passenger tire so I jacked it up tried spinning the wheel and when I did, it felt like the brakes were on slightly on and I noticed the front axles and drive shaft were spinning with the wheel, WHY? Wouldn't that mean the hubs are still engaged? I then went over to the drivers side, jacked it up and the brakes felt even harder and the axle also spinning. I dropped the truck down baked it up , engaged 4hi and then back to 2wd, jacked it back up, and then checked to see if the hubs disengaged and the wheel spin without the axle! So I drove it and it was still makin the noise. Then I got my lady to drive my truck while I walked next to the truck and determined that it was coming drivers front tire. I went right back home and jacked up the drivers side front and tried to spin the wheel and it the axle was spinning again. WTF. It also felt like the brakes were still on. So I took the caliper off and discovered the pads are wearing uneven on an angle from the inside to the outside. again WTF!
So I think I have to problems. Why are my hubs engaging in there own??
I just did the brakes 2 months ago ( turned rotors and new pads from autozone).
I am a little confused how the pads wore like that. The rotor is tightened down with the lug nuts, the caliper bracket only goes on one way, and the caliper is aligned with the slide bolts. The only reason I could see the pads wearing like that would because the pads were crooked but wouldn't the caliper applying pressure flatten the pad out against rotor?
Rookie
Fort Wayne, IN
Got everything packed to head out tomo. Went to test the gps and my XGPS160 won't turn on. It gets warm like it's charging but I can't get it to do anything. Ordered a 150 since there's no time for warranty games and had it sent to my dad's house. Hopefully it gets there in time.
