Side window deflectors
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Doesn't the in-channel shades not seal very well.
Isn't it the glass against the plastic?
Or is there some kind of seal built in?
Sorry, by 'seal', I meant 'watertight'. When a deflector fits inside the window opening, then water sheds over it. Just like shingles on your roof, they run on the overlap concept. Stick on ones only rely on the tape for a seal, and the tape is usually cut into pieces to fit the contour of the window.
Yup - the glass is against the plastic when closed. It's still as air tight as stock was, because of the pressure on the inner window trim.
They use the same two sided 3M tape, but it sticks to the inside of the outer window trim.
Raptor Retrofit
HID Specialist
NY
That was the exact reason I took my weathertech's off. Mine didn't seal very well and they creeked and squeaked all the time. Plus, my window was not going all the way up into the channel either.
I really want some, but I don't want to stick them on.
Another issue I read of with the in-channels is they will trigger the safety feature on the auto-up windows on the 2011's
I've had no issues with the stick on ventshades except for the wind noise.
IRONMAN
Well-Known Member
MICHIGAN
Thanks for the pics JP7, See I have tint and I'm also curious if that will scratch the tint? 2 hard surface objects constantly rubbing against each other doesn't seem like it would last with out scratching. Also what is the main reason for these vents, is it just because of water dripping inside the vehicle? Or is it also just to deflect air away from the inside of the vehicle?
Raptor Retrofit
HID Specialist
NY
Your tint is on the inside so it wont scratch that because the outside of the glass is what comes in contact with it and Ive read ppl saying it will scratch the glass.
The main purpose is so you can crack your window for ventilation while its raining. they actually disturb the airflow around the truck so its a bit louder but its well worth it, IMO.
IRONMAN
Well-Known Member
MICHIGAN
So it's just a straight flat edge that goes into the window channel and not cupped edge on the vent shades. For some reason I was under the impression that it was a cupped edge that went into the window track. So it just stays in there with a sticky side then, is that right?
DocSpooK
TechsAzz
I had to bevel the edge a little with my dremel, but then it would hit it and guide into the channel without tripping the safety down feature.
Raptor Retrofit
HID Specialist
NY
Nice tip, for all you lucky bastards with the auto up feature.
