GEN 2 Shudder at Idle with AC on.
dinoone
dinoone
Sorry to hear what is happening man, I can't believe they are going to go this route and screw you over. Again how can they prove the tune killed the ECU?
dinoone
dinoone
Plugs pulled don't look bad going to clean and gap at 28 degrees
dinoone
dinoone
BajaFred
Did you really? Do it with the factory
Sent from my Nexus 6P using Tapatalk
I'm confused, I thought he just put the aftermarket IC back on
Dino, did you drill the factory IC yet? Or did you drill the aftermarket one? Or neither?
dinoone
dinoone
Aftermarket intercooler back on! No stock on plugs coming Monday with updated tunes from 5 Star. No damage to ECU as the strategy is still the same as before. I'll drill hole Tuesday
Bullishone
So you'll drill the hole on the lower pipe of the intercooler I guess. Same as factory. Sounds like a plan.
dinoone
dinoone
You will want to drill in the lowermost, driver side corner where the condensate pools.
Question so if there's no condensation whats the hole going to do for me?
Sasquatch77
Banned
Your intercooler will produce condensate while driving around. The hole allows that to evacuate outside before being forced through the spark plugs. Drill the hole and then drive the truck hard for a few miles.
