Show off your latest pics
TomDirt
Hesperia CA
There's gotta be some actual engineering involved when they call out aluminum torx bolts in an aluminum case.
That hardware is available somewhere. As much fun as it was to remove & replace that 80lb transfer case & that 220lb 6R80 trans, I went with the oem hardware & torque settings because I don't want to think about something failing later.
The Car Stereo Company
here, on frf
Today's project: figuring out how to get 325ft/lbs on the new steering rack bolts with an aching wrist.
#GettingOldIsn'tForSissies
well if 2 goats weigh in at 150 pounds each, i believe putting them on approximately a 13 inch rod will get you the results you need
