Should I go two Baja fogs or 3?
Ruger
Northern Nevada
The OP asked about fog lights. I'll answer that question! There is a sweet spot with regard to how much light you can use in fog before it gets reflected back to you and becomes badly counterproductive. I went with one pair of Diode Dynamics SS3 Stage 3 DOT/SAE Sport amber pods, and I think they produce close to the maximum you'd want to use in heavy fog conditions. They are down in the bumper cutouts, which is a bit high, actually, for fog lights. The idea of fog lights, of course, being that they are low enough to illuminate the road in the clear gap between the road and the bottom of the fog layer. The height of the Raptor's bumper cutouts puts a genuine limitation on how effective fog lights can be in that location. Bear that in mind. Too much light projected INTO the fog gets reflected back at you.
I also have amber halogen fog lights (halogens get hot enough to be self-cleaning [just in case]) down in the lower grill at about the same level as the DD SS3s. Also amber halogen street legal driving lights and white PIAA halogen off road lights up above the bumper. Every pair is individually switched so that I can adjust to accommodate to conditions in real time.
4wheelinAZ
4wheelinAZ
AZ
Fantastic info. Thanks. I’m looking at upgrading more for light on the trails in addition to everything else more so than helping in fog. I live in AZ and see fog very very rarely. But good points nonetheless
You definitely want some lights higher up as well then. The bumper pocket is ok for in close, but they’re pretty easily obstructed, relatively. The S8 behind the grille kit puts out light at slightly higher than headlights, which is really good. You lose -some- throw from it, but not as much as most people think and once you light it up, you can see a lot better.
That’s not to say discount the bumper pocket lights, far from it, they can help in moderate dust conditions.
OffroadAlliance.com
Boston, MA
Definitely agree, for the most part. You can for sure get some good long range out of the fog pocket lights but it's an area of your truck that is most blocked by debris, dust, etc so it's good to have lights higher for a nice unobstructed long range pattern.
@4wheelinAZ we've got the S8 kit in stock here: https://offroadalliance.com/products/baja-designs-2017-raptor-30-s8-behind-grille-light-bar-kit/. We've always got good pricing for FRF members.
4wheelinAZ
4wheelinAZ
AZ
Thank you sir. Nick has a quote out to me
4wheelinAZ
4wheelinAZ
AZ
Agree 100%. Adding light in the grille is definitely on the menu, just trying to offset purchases to ease the wallet.
4x4TruckLEDs.com
The 3 pack looks kind of weird down their. Should I just go with the 2?
Go with a triple setup. Our brackets were designed specifically for the Gen3 Raptor. They allow you complete control over how the lights sit. This means your lights won't stick out or look weird sitting at awkward angles. They sit nicely in the opening.
Here are some examples. And our kits are 10% off right now (discount added once in your cart) in celebration of the 4th of July (Sales ends this Friday, the 8th):
https://www.4x4truckleds.com/vehicle-specific/ford/ford-f-150/2021-f-150-raptor/fog-lights/
These are with our KR Off-Road brackets (made in the USA with a lifetime warranty!)
