Geo_Tactical
The mid engine C8 that's been bending frames is rumored to be putting out in excess of 1000 HP. The ZR1, which is rated at 750 HP uses the same frame as the 650 HP Z06 without issue. I assume that Ford wouldn't simply throw the motor in, slap the tailgate and then say goodluck. They'd need to, as you said, upgrade certain components such as the driveline and cooling system. Certainly not huge obstacles, especially with 2 years to work out the kinks.I think this nails it right here. I've been reading bits 'n pieces here and there about the new (C8 or C9, I forget) 'vette bending the space frame with it's current powertrain configuration. I think the tranny, drivelines, diff's and axles would all need an upgrade to handle that much power/torque. And the frame rigidity would need a significant upgrade as well. Maybe even permanent AWD...gawd forbid, otherwise you'd be smoking rear tires through the first 7 gears. Also if you put any payload/trailer on it, you'll be looking at needing a significantly upgraded cooling system (bigger or multi-core radiator) which is going to make it even more front-heavy, contributing to under-steer. Maybe the engine itself will go in, but they may have to de-tune it.
Sent from my Galaxy Note 8 using Tapatalk
