bstoner59
does it come in shmedium?
I always have coffee!!
I'll admit I'm confused by your response. On one hand you say that you won't post information because it might inspire someone with lesser knowledge than yourself to make or market their own set. Then in the next breath you say you purposely didn't mention the dangers of hydrogen embrittlement during heat treatment? It's this kind of information that would keep people from buying from critical parts from people who don't know what they're doing! And it would keep anyone with a drill press and a lathe from thinking they could just throw their own kit together.
As far as Herbst and the aluminum rods... I know aluminum tie rods have been used by many racers. I've used them myself. But it's very possible that they use much larger and stronger threads. (I'm not up on trophy trucks but my guess is 1" or 1.25" is used... much stronger than 0.75")
Oh, one thing I'm pretty sure of is that most trophy trucks weigh less than a Raptor.
But you didn't claim your tie rods were made from aluminum like the trophy trucks... you made specific claims when someone asked you about thread strength.
What caught my eye was your claim that a 3/4" thread in aluminum was stronger than the stock 0.472" steel threads... that fine threads are stronger than coarse threads... and the implication that more thread engagement than stock adds substantially to thread strength.
All of those claims are hard for me to believe and you aren't backing them up with any engineering or test data.
As far as thread engagement? If I'm wrong, show me where. As counter-intuitive as it sounds, the first few threads carry about 80% of the load. In softer materials, the loads spread out a little more but there is no significant increase in thread strength once you exceed an engagement 1.5 times the bolt diameter in aluminum.
In reality? Ford's tie rod threads might be 10 times stronger than they need to be. Your threads might only be 7 or 8 times stronger than they need to be. Both might be overkill. But that still doesn't make it right to claim something is stronger than stock when it may not be.![]()
Annnnnnd.... It's on.
Mark,
SNIP As you know, lab testing like you are mentioning is very expensive and not many vendors on here could afford something like that unless people want to spend $1200 for a steering Tie Rod. We are not a multinational company that can just pay for Lab testing.
SNIP Unfortunately we can only worry about what we produce and aren’t in the business of writing online text books to help people reproduce or copy what we or any other manufacture have built. SNIP
If I recall correctly the Herbst truck had on average of 100 more tubes designed into it when compared to the next closest competitor’s truck, and the guy who designed the Herbst truck is a legend with basically what was and unlimited checkbook.
I don't think you are anyone else will question that the hardware used in the RPG Tie Rods is far superior to the OE application. This leaves the debate about the Rod itself. I personally think Cory explained the strength of the rod the best he can but I will make sure to have him give a detailed pic and write-up comparing RPG rods vs. OE rods.
I hope you have a blast on the Mojave trip and hopefully I get a chance to meet you Barstow. That’s a great trail with perfect terrain for the Raptor, should be a really fun weekend for you guys.
Best Regards,
Jarrett
my understanding of fine v coarse threads has always been that when comparing two identical joints(size, material, length, thread engagement, etc) that a finer thread will be stronger in regards to tension and loosening from vibration. longer thread engagement, thicker diameter, finer pitched threads...RPG is making all the right noises. the only unknown for me not being an engineer is alum vs. steel. otherwise it all seems in check Mark
I only mentioned the thread testing... which does not necessarily need to be done in a lab... because of the claims made that a 3/4" thread in aluminum is as strong as steel threads. :deadhorse:
Never asked for an online textbook. Just wanted to see the justification or some proof of the claims made for thread strength.
And they used what diameter threads on those tie rods? If the RPG rods use the same size threads as the Herbst truck, then it's valid. I had an RC car with aluminum tie rods too but I think you'll agree it's ridiculous to make the comparison to a Raptor.
That would be interesting.
I plan to have a blast! Not planning on debating engineering topics. I think I've said more than enough.
---------- Post added at 06:12 PM ---------- Previous post was at 05:48 PM ----------
I have a little "hands on" experience in testing this kind of thing as well as some engineering background. Anyone interested in the facts about threads can probably find more than they'd ever want to know on the Internet. Here's two links to get started:
General info:
http://www.fastenal.com/content/feds/pdf/Article - Screw Threads Design.pdf
More specific info on thread engagement stresses:
http://www.bastionogp.com/technicalPapers/Bolt Thread Loading.pdf
You'll note that in their example that the sixth thread is carrying less than 2% of the load. The seventh thread would probably carry less than 1%. The eighth, even less. More thread engagement, as counter-intuitive as it sounds, does not mean significantly more thread strength.
From my experience to equal the strength of a 0.472" steel thread, you'd need to be using somewhere around a 1" thread in aluminum.
Again, I'm not saying 3/4" won't work just fine. (I really don't know). I'm just saying I have a hard time believing it's "stronger than OEM."
the first link clearly says fine threads are stronger in tension? i'm not trying to argue, wondering if we're trying to make 2 separate points.
Page 4, right?
It says fine thread bolts are stronger in tension. This is because fine threads are not cut as deep so the bolt has a larger minor diameter.
This is not the same as saying the threads are stronger... in fact, on the opposite side of the comparison it says about coarse threads: "Stripping strengths are greater for the same length of engagement"
Fine thread = stronger bolt
Coarse thread = stronger threads
However, a bolted joint should be designed to
always force the failure in the bolt shank and not in the thread and therefore, if designed properly, this type of thread stripping should not occur.
The above findings also suggest that a larger number of engaged threads (fine pitch) will
improve the performance of the joint as the stresses are distributed over a larger area; hence
reducing the resulting local stress concentrations.
right, so do you think the tie rod shaft its self would yield before the threads stripped based on its application, making the overall strength of the shaft more important than the type of threads?
I'm really not bashing the part or the design... just some of the claims and statements.
For one, coarse thread rod ends might be made of "unobtainium" so you might have to use fine thread. I understand that. But the fine threads are not more resistant to stripping than the OEM coarse threads and more thread engagement than OEM does not add much strength. Those claims are what I'm questioning.
IMHO, the internal aluminum threads would fail in tension before the steel rod end threads or the tie rod shaft. And this might actually be a good thing. Kind of a "fuse" in the system. If the tie rods are too strong you could easily destroy the rack or spindle. I'd rather have a tie rod tube fail first.
