surfer
Yes,
Thanks for the Pictures.
I'll Just add them to your tab![]()
Jarrett,
First forgive my ignorance but do the aluminum threads on each end of the spacer bar measure up to steel ones as far as longevity/strength is concerned. Thanks
I'll be calling you around Monday 9th to get everything rolling. Figure I am into you guys for $3200+ right now....
-Greg
The strength of the thread is porportional to a couple different factors.
1. fine thread vs. corse. Finer thread is stronger because of more thread engagment per lenght of thread.
2.Diamter of thread. Factory thread is (.472") vs. RPG Tie Rod of (.875") for the outer tie rod thread and the inner Tie Rod thread is (.750")
3. Final factor is length of thread engagement. We have maximized the length of thread engagement by design for maximum strength over the OE application.
To put all of this in simple terms. When looking at the overall strength of material vs. material, multiple factors have to be taken into account. Its not really an apple vs. apple strength test because of the factors listed above.
Long story short, you will rip a factory rod apart long before you will an RPG Steering Tie Rod.![]()
This can't be "proprietary" information... why not just post the actual engineering calculations? It's not that complicated.
Better yet, how about a destruction testing comparison? We'd all like to see that!
Aluminum threads have only roughly half the strength of steel threads... and while the fine thread bolt itself is stronger than a coarse thread bolt, coarse threads are usually used in aluminum because they have deeper threads and therefore are usually less susceptible to stripping. The deeper threads are the major reason a fine thread bolt is stronger than a coarse thread... the deeper threads makes the minor diameter of the bolt smaller... but those deeper threads are an advantage in relatively soft materials like aluminum.
As far as thread engagement, the first thread carries about 34% of the load! And once you go beyond a thread engagement of about 1 1/2 times the diameter of the bolt (for aluminum) the extra length of engagement does very little for strength.
I'd be concerned trusting aluminum threads in this application on a 6000 lb + truck.
Marketing talk is good... but do you have any testing or engineering data to back up the strength claims?
Looks great installed... Hell, strength aside just the look alone is tempting me!![]()
