RPG Texas Raptor Run: TRR14 April 10-13 2014
treypal
treypal
Lord of the Raptors
Riviera TX
TRR is proud to announce NITTO Tire as The Official Tire of the RPG Texas Raptor Run 2014 Presented by FOX. NITTO makes an awesome tire, and we're excited to have them on board for the event!
iSurvive
Highlands Ranch, CO
Couldn't find the instructions SHO-ME Strobe-Style LED Flasher
There's the link to the flasher
Available on Amazon. Very easy to install. The issue would be changing them from the flash pattern you want and "always on". You would have to see the lights while you adjust the pattern. Each time you give the "white" wire power, the mode changes, and you have to cycle through each pattern (seven I think) until you get to the one you want.
OR
You could hook up the flasher to the lights (leaving the white wire hooked to nothing) and add a switch for "constant on". In this case you would apply power to the white wire until you get the flash pattern you want and then leave it alone - it will stay on this pattern. The you need a special splitter (diode) that lets you feed power to the lights from the flasher module AND the switch for "constant on".
So:
a) send power to the flasher, you get strobing
b) send power to the light, you get constant on
DesaRaptor
OR
So:
I used the same diode packs to wire my rear bumper lights from the trailer harness reverse lights and upfitter switch.
Big Blue
Administrator
Staff member
Admin
USA
Members online
96,162
60,007
xplosiveg06
