Rotating the Driveshaft?
rschap1
Lowell MI
I was picturing the entire shaft (both halves) being removed, kept together, and replaced.
I can see where pulling the spline apart and not aligning the two halves might be an issue.
SCAR911
Arizona
Howdy,
Long story short: Local shop didn’t draw an index mark on the attachment point, and seem to have bolted the driveshaft back on in a different orientation, causing a driveline vibration.
I have no experience working on driveshafts, so I’d like to attempt to tackle this myself and learn something. I’m just unclear on what the process for rotating the driveshaft is? Remove the rear bolts, put it in neutral, twist 90° or 180°, and rebolt? Or does the entire assembly need to be removed and reinserted?
Apologies if this comes off as asinine.
The only driveshaft you need to do that with is a 2 piece. We have 1 big solid ****. Should go in any position
FordTechOne
Detroit
All driveshafts need to be index marked before removal regardless of one or two piece. It will bolt up in any position, but you’re taking the risk of inducing a vibration if it’s not indexed.
MDJAK
NY
I'm not a mechanic. As far from it as @Oldfart 's goats trying to flee when he's on the prowl feeling h o r n y and r a n d y.
But, what stands out to me is the OP stating he has no experience with driveshafts. I'd want it fixed right by a dealer or go back to the idiots that didn't do it right in the first place.
SCAR911
Arizona
What are you marking? The yoke going into the transmission and flange bolting to the rear end? How is that "Calibrated" in the factory?
nikhsub1
Los Angeles
Yes if you entirely remove the drive shaft you should mark both ends... Also as I stated, if you remove the flange to replace the seal you should mark the flange as well to put it back exactly where it came out.
SCAR911
Arizona
If you are taking the flange off, I get that. It may be balanced with it but taking it off and on, I don't understand and may seem like a urban myth. It's not balanced to the trans or diff.
nikhsub1
Los Angeles
Well every video of every tech I watched on how to replace the pinion seal all marked where the drive shaft connected to the flange and marked where the flange went into the diff, so that's what I did and I have zero issue. Maybe it's a myth and maybe not, but it takes seconds to mark to make sure you won't have a weird issue.
FordTechOne
Detroit
On a slip yoke you’re just indexing the driveshaft to pinion flange connection. It’s not necessary “calibrated” from the factory, what you’re trying to avoid is inducing a vibration that wasn’t there before disassembly.
Domin0
Domin0
PA
My wife keeps telling me to do the same thing :emotions33: Stubbornly treating it as an opportunity to learn something new, and I don't want to make the drive to the dummies who induced the problem in the first place.
