Review: Alcon Brakes for Gen 2
Nex
RIP CoronaRaptor
Washington State
Anyone know why these kits don’t fit the gen 3 trucks but fit the regular 21+ f150s? I don’t see why the calipers would be any different, maybe different brackets?
More than likely it's due to space between the caliper and factory wheels. I had an issue with my Method 305 20" but appears that the 105 17" fit with the supplied 7mm spacers.
catinthehat85
Socal
Thanks, if they’re going to introduce some wild redesign with a premium markup I’d rather just order the roush calipers, 21+ brackets, and a thicker spacer or new wheels.
Nex
RIP CoronaRaptor
Washington State
You can check out my build thread for the problems I ran into on my '18.
Post in thread 'Nex Gen 2 Build' https://www.fordraptorforum.com/threads/nex-gen-2-build.86192/post-1795056
You can also just order the brakes, brackets and take a gamble at them fitting the Gen 3 factory wheels. Be the test dummy.
catinthehat85
Socal
Method 105 17" beadlocks fit with the supplied 7mm spacers. Zero offset.
Very nice. Curious how many turns you got on the front lugs with the spacers installed? My gen2 had longer lugs in the back, so I’m curious how much thread engagement you got on the fronts with a 7mm spacer in the equation.
Nex
RIP CoronaRaptor
Washington State
I didn't install the wheels myself, no time. But my guy has done this a few times and would have told me if they were not safe. We were looking at longer front studs to run the 20" 305s instead of buying new wheels.
He has another customer that ran into the same issues with Alcon brake/wheel combo that they are going the longer stud route. I just saw it as an opportunity to switch over to beadlocks.
catinthehat85
Socal
That is super interesting to hear. I spent 4 months searching and could not find any product available…anywhere from any vendor that made longer studs for our trucks, 1.5 pitch or even 2.
nikhsub1
Los Angeles
Could have just went with bead grip and saved a bunch of time and spacers :p
