Retrofitted LED Tail Lights
McDowell
Oklahoma
Wait is it iron man that does the light or rsiworks? I got confused, sorry. Also are you cutting them apart and then resealing them or baking them and then resealing them? Just curious
Sent from my iPhone
IRONMAN
Well-Known Member
MICHIGAN
Sent from my iPhone
I'm both IRON and RSi.
You have to cut them open, you can't bake them apart I've tried and it wasn't pretty.
McDowell
Oklahoma
Ok sweet thanks for clearing that up lol I used to do Chevy lights having tried some ford ones though
Sent from my iPhone
IRONMAN
Well-Known Member
MICHIGAN
Well, update for you guys.
I will NOT be figuring out how to control hyper flash anymore with load resistors or what not.
There is one fix and the BEST fix that can be done for this. Basically you take your truck into FORD and have them delete the code from the BCM that tells your trucks lights to flash fast.
I've had 2 customers to date do this and they no longer have the problem of the dreaded hyper flash plus they are not running load resistors.
ALL GONE!
Basically print this out and take it to your Ford dealer and tell them you want it done to your truck. Cost is roughly $100
https://www.fleet.ford.com/truckbbas/non-html/Q-158R3.pdf
My truck is in the shop as I type getting this done.
Evanscott29
San Diego, CA
Does this mean you're still gonna make some sweet tails and in conjunction with this sve we will have the most awesome non hyper flash tails on the market?
PropDr
Eugene, Oregon
Is this for both, frond and rear?
ALL GONE!
Yes it is!
IRONMAN
Well-Known Member
MICHIGAN
Well just got back from my dealership and they couldn't do it or didn't know how to.
I'll be taking it to another dealer but I might run into a problem cause I've been told that the BCM's are different on the 2010 Raptors compared to the later models.
So basically 2010 Raptors might be screwed, but I won't give up.
Mogo
Colorado
ALL GONE!
Damn, I knew it! I was hopeful that something could be done like this.
:challenge:
http://www.fordraptorforum.com/f81/led-turn-signals-hyperflash-bcm-reprogram-28941/
Now get to work on those tails so that I can rack up some more credit card bills!
Members online
96,856
60,809
hazardsyd
