- Joined
- Dec 16, 2016
- Posts
- 18,022
- Reaction score
- 28,091
I was originally interested in a single MTI 10” enclosure. Unfortunately you have to cut out the backing on rear of the cab and it looked to be an extremely tight fight. Can you still utilize the factory jack location? It was also mentioned by @dhmcfadin that your woofer will be literally pinned up behind the seat, which is not optimal.
I really wanted to utilize an enclosure like this which worked behind the seat. I stayed away due to these issues and was looking at a single under the rear seat 10, once I abandon the dreaded factory enclosure. If you can speak differently about it, I’d certainly listen.
The MTI single 10/12” enclosure does require trimming, true, but, you can dynamat for sound if needed, and I did it. if I can do it, you can too. hell, I cut the damn backing with a ZT350 serrated blade. You relocate the jack, yes, but you can fit it in the below the seat storage enclosure and strap it down for any potential roll overs.
The improvement in sound, bass depth and punch is well worth it.
