Recommendations for Bump Stop
Loufish
Burbank CA
I was able to locate the SVC nuts inside the frame by bending the included wrench but added at least 30 min to my
I thought about using a cheap Craftsman wrench and doing a heat and bend to make it a little stronger then the supplied open end wrench...
Thanks for the install tips!
brettmess24
Absolutely it’s a challenging install but easily done.
I think you will find the wrench idea easier said than done, and a lot of extra effort. The supplied wrench actually worked well and I needed the ability to bend it easily as well as being flat to position it inside the narrow openings.
