FMI Gen 2 Raptor Front Limit Strap kit
SRQ_Raptor
Sarasota, FL
@GregFoutz To install these, do the front shocks/springs need to be compressed at all? Looking for a solution to keep my gen 2 live valves with eibach springs from topping out.
Auxlry
Riverside, CA
I installed these myself and no you do not mess with the front shocks at all. You do need to be able to weld the mounts to the frame and the rest is bolt on. The straps would be installed with the truck on the ground.
SRQ_Raptor
Sarasota, FL
Thanks! @Auxlry. I don’t weld but I have a capable shop close by.
GregFoutz
GregFoutz
does this interfere with FRS hoses for the Resi?
yes but for the non live valve version we have a hose kit we can get for you that will clear everything. We have installed the limit strap kits with the fox shock but have to change a hose and couple of fittings so they clear and not rub through. you can call our shop and discuss with Jake at 480-718-9800
we can do with this version just to be clear. It has standard hose ends and we can make a setup to work.
This version with the live valve we are working to try and get hose fittings to make custom hose layout to clear like this link. But as of now this one will not work with the limit strap location.
