Recent CarPlay issues with Volume
Nibbl3s
Hey everyone i figured I would post as it took me a bit of research to find out.
I was having trouble with CarPlay (specifically Spotify) where o would not have any control over the volume. I would try to raise or lower volume. This just started recently as well so I figured something updated and broke
After some research, some others on f150 forum tracked it back to waze. If you are have omg any problems with volume on car play, remove waze for now and it will fix this issue
Crunchtime2k
Ohio
Same here , never had waze installed, using a iPhone with the latest iOS and sync 3.4 build 20021
Raptor911
Ashburn, VA
Power down your phone completely and then turn it back on and you should have vol control while in CarPlay.
JohnC12
Leesburg, VA
Does the power cycle fix the issue indefinitely, or do you have to power cycle every time you connect to CarPlay?
Sgt Beavis
Colorado
I was looking through Reddit and Twitter and found that Waze has acknowledged they caused the issue and are working on a fix.
dmb359
Minneapolis
They responded to my email and said they are aware of the issue, and asked me to run Waze in debug mode, reproduce it, and send them the log.
Crunchtime2k
Ohio
Its not a waze bug exclusively , it is triggered from using apps ( certain ones ) on the phone while connected to carplay.
