Charging issues
MTF
Celebration, Florida
Corrosion and/or loose nuts at the starter terminals is a common problem.
Disconnect the battery and then unbolt the nuts and clean all the eye end terminals.
Maybe use some dialytic grease.
jdm_sixtwo
jdm_sixtwo
11MPG is average, right?
Beaufort, SC
Checked the nuts and none are loose, but they’re all oily. Assume that’s probably not the best for them, so tomorrow that’s what I’ll do along with checking what PCM is commanding
MTF
Have you unplugged the three PCM connections and checked for corrosion?
bwep
Mass
There was a thread on the F-150 forum with a guy similar problem.
He ended up putting a new ignition cylinder in. As soon as he did that his fuse 27 blew.
He seemed to think the fuse was the intermittent problem, not the ignition cylinder.
You might want to look at both as a possible problem.
jdm_sixtwo
jdm_sixtwo
Beaufort, SC
I have a relocated fuse 27 already. I did have the truck just click one time when I tried to start it, but I just cleaned the terminal and it fired right up.
