Battery Light
BSouders80
NW Arkansas
At what voltage does the PCM kick on the battery warning? I was driving on highway at 65 mph and the battery light on the dash came on. Very random. I grabbed by tuner real quick as it shows the current voltage in the "about" menu. I was around 12.55 or 12.60 volts. I did look again later and I was closer to 13 volts.
Just curious when the battery light does kick on.
TIA
Brian
rschap1
Lowell MI
I just went through a LOT of head scratching until replacing the alternator on what is my daughter's Lincoln MKX. A bit of a pain to replace, I wanted to make sure that is what was needed. Sounds similar to what you are describing. It would work intermittently. Whenever the light would come on it would show battery voltage 12.4+. With alternator working it would be around 14 or more. Finally replaced it and all better. Good luck with yours.
Nesc204
How much mileage do you have? I had mine rebuilt at 170k. The brushes were down to the nubs. Did it just in time or I would of been dead on the road
B
BSouders80
NW Arkansas
Truck has 101K. New alternator was installed when I put in the 6.6L. So the alternator has around 16K on it. Unfortunately, it's under a whipple, so not easy to change out. Is the voltage regulator inside of the alternator? O'Reilly's has a way to test alternators that are installed I do believe. I'll grab my truck on Friday and do some testing.
Nesc204
I'm pretty sure its built into the alternator. Not to get off subject but how you liking that 6.6 or is it the Livernois 6.7?
