Netix
Banned
im gettting my rcv gen 2 really soon
Were you in 4-wheel drive on the highway?
Then your axles should not be rotating.No...
Just broke my 2nd CV axle boots on top perch on a ******* highway !!!!!! Was driving 250km distance and saw smoke coming out... Moments later grinding noise from beneath , knew it was the axle LH (driver side)
This happened to me twice in less than a month now
Im serioulsy upset running on top perch .. I dont know what to do , i have deaver +3 and rear end is really high , i cant go back to low perch , im so frustrated about the stupid axles , i feel its the weakest link in the car and its not made out of good quality
Tried RCV and all the bad luck followed ..
Any suggestions ?
I agree unless you have a vacuum problem and your front hubs are engaging. Then the axle will turn but not be in 4 wheel drive.
Put a vacuum gage on your front hubs and see if you have a leak. If you have a leak the hubs default into engaging.
Why not drop it to mid perch and see what happens once you get the hubs and axles situation fixed.
