RAPTERRIER
Full Access On Your Mom
- Joined
- Jul 28, 2016
- Posts
- 900
- Reaction score
- 629
I think in a way they have told us the HP number. If you look at the ford official brochure it lists the new std ecoboost torque as 470 and the high output one will go much higher. In the weight saving section it says they shed nearly 500lbs increasing power to weight ration by over 16%.....
So if our current 6200lb screw has 411hp then the power to weight ratio is .066hp/lb. A 16% increase gives us almost .077hp/lb. At 500lb savings we get a 5700lb screw. So HP for the new ecoboost would be right around 438 ponies.
I could be wrong but they gave us that info just not the numbers.
That above is the best educated guess I've yet seen. I wouldn't be surprised if you nailed it...
