I'm reveling in the irony here. Coming from serious tuning of Subarus it's interesting to see everyone go through the same learning curve. For example, the WRX and STI used to share the same block, the EJ25, that was used in the cheapest non-turbo Imprezas and Outbacks, and the forged and nitrided crank was the same on the WRX and the STI (and cost just a couple hundred dollars as a part), and yet with just case bolts you could push that stock block to over 500 crank hp. People think the manufacturers won't put more power in their cars because they can't, but a lot of times the limits are found in certain parts or discrete weaknesses. For example the stock STI pistons are a real weak point. Swap those out (along with case bolts and a few other "cheap" parts) and you got to over 650 crank hp before the block case itself would start to twist and separate and the heads would deflect and you had to start worrying about leaks there too.
What I'm disappointed about is that I would have thought there would be a lot more experience with this ecoboost engine given it's been around in different forms for over 10 years and is in everything from 35k work trucks to 250k supercars. The tuner market for Subarus and others is huge but apparently not well represented with Raptors. Personally I'd love to turn mine into a desert racer but that will have to wait. I guess they are just too expensive and people aren't building 800 hp work trucks.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I will add that I found this builder that claims the stock crank is good for at least up to 700 whp so clearly the problem is not the crank. I also notice that the block is an "open deck" block so there's plenty of space for coolant flow around the cylinders, which makes me wonder about the guys reporting high cylinder temps as a tuning problem down at ~500 whp. I have to think the problem is elsewhere- sufficient total coolant flow, undersized stock radiator, insufficient or badly placed coolant channels in the heads, who knows?
https://www.rmbmotorworks.com/product-page/rmb-motor-works-stage-1-gen-2-short-block
