nikhsub1
So, as a lot of you my rear end was squeaking, sounding like a rust bucket for the most part. I've lubed before with some degree of success. Yesterday while trying to install my spiffy new RPG shackles, I had the truck in the air on jackstands where the suspension could fully droop. After being unsuccessful at being able to remove the upper shackle bolt (frame is in the way, can't slide bolt out) I decided now was a great time to do some rust touch up with Correseal and also, lube the shit out of things back there.
With the suspension fully drooped, I sprayed Jack of All Sprays in between the separated leafs, the upper and lower shackle bushings and the front mount bushings for the leafs. I went for a drive this morning (down Melrose to see the looting carnage in my hood) and the truck was DEAD silent.
Like I said before, I've randomly gotten under the truck with lube mostly with not great results. I guess my point is, the best way to lube under there if you are squeaking is to fully droop the rear end, then lube.
