New leaf springs I just got under warranty are sitting to high.
downforce137
In Diana
Shackle nuts are 135ft lbs.
Frame nuts are 260ft lbs.
TomDirt
Hesperia CA
Does the factory use grease/lube on the shackle bolts to limit squeaking?
downforce137
In Diana
Nope. It's not a performance bushing.. it's a comfort/quiet one from the factory.
They are also molded to the center area the bolt goes thru so that's why it's a big deal to torque at ride height..
The deavers use energy suspension poly urethane that need greased..
the poly ones the center sleeve floats which contributes to noises
