Programming a third key
nfsraptor
SoCal
Worked great, got a key for 80 USD for my Gen 2 2017 from eBay (New) the 2017 key is so ******, the 2018 is a solid feel and way cooler
Do you have a part number or eBay link you used to get the 2018+ key? I also like that better than the 2017.
Also, do you know if I got two if you could program all 4?
FullSend
Colorado
Man that took me less than 30 seconds to do, thanks for sharing!!
Sent from my SM-N975U1 using Tapatalk
Faze Star
Florida
Any tips on why my key did not work? It programmed successfully and it ONLY turns the car on but nothing else works.
PepeMnz
Houston
Does any body know if the 2018 fobs(new style fob ) are able to get programed on the 2017(old style Fob)
TimTim
Orange County, CA
Yes. Today I successfully did it. I had 2017 keyfob and bought raptor keyfob 2018+ with different FCC ID ( found out later ). I made programming by myself in the truck’s cup holder. You needs to use both old keys to do it.
Reptar854
Savannah, GA
I recently bought a replacement 2017 Raptor (Other one got totaled) that only came with one key fob but I still have a spare key fob from my old raptor. Will this process still work so I can still use this spare key fob?
FordTechOne
Detroit
No. That procedure requires two programmed keys.
You may want to look into the ForScan extended license, I believe that has the capability to program an additional key.
