Pro Eagle Jack Options
Gdog
Colorado
Thanks.
I got the 2ton big wheel/ offroad jack as a bday gift from my wife.
For what I need or might use it, the 2 Ton will suffice.
But if you spend alot of time off- roading and need to change wheels/tires often then I suggest getting the 3T (only a few pounds difference in jack weight anyway)
Thanks for the info
ShadowRaptor
USA
Just to put this in here:
ProEagle alum jack weight:
2 Ton offroad (non-big wheel) is 46lbs
2 Ton big wheel is 52lbs.
3 Ton big wheel is 60 lbs.
(as listed on pro eagle website)
Halo Raptor
Monrovia, CA
Ive got the 2 ton skid plate one and it works bitchen in the driveway, in the garage, and in the desert. I opted away from the wheeled one so it would stay still. Mine lift my fat pig Raptor off the ground with zero problems. I got the Pro Eagle cradle and JDS Customs mount for the bed and it came out sweet. Never had any problems with it
Booth9999
Idyllwild
Same here 2ton with the same cradle and 0 problems. The skid on the bottom works super good in the sand. Also just picked up a handle holder from Krazy house kustoms that attaches to the box link super sweet and spring loaded.
mpk1996
Looking at the 3T myself. With the big wheels. looks like the mount will hold the handles under. So that should mount well on my bed rack. Don’t want to put it on the BuiltRight rack. To heavy to turn on its side.
my older craftsman 3.5T has been good. But it’s at its limit getting the truck off the ground. Time for an upgrade.
