Premium vs. Plus vs. Regular
FarmersFight
Manvel, TX
I've had my 2018 Raptor for about a month now (has 32k miles), and curious if I should be buying Premium gas, or Plus, or Regular. I obviously don't know what the previous owner used, so curious if I should make the decision now to only use Premium going forward, or what issues I should take in to consideration.
I've seen some other threads on here talking about this, but not really discussing this scenario-- i.e. buying used and then buying only Premium or Plus. Thanks in advance for the recommendations...
Proflyer
Denver
Braaaaptor
Starbucks Enthusiast
The drive-thru
In the manual it specifically states that 93 octane is optimal for the HO EB. You can certainly run lower octane just know that your engine has knock sensors and will retard mentally handicap your truck. It can take a tank or two to get those sensors to reset to spicy fuel but IMO you shouldn't skimp on fuel on a TT high performance engine.
You gotta crack some jalapeños to make the salsa spicy!
