Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I went with the Icon powersteering cooler. Bolt on brackets are nice and solid but the cooler is cheaply made. The pieces on the top and bottom of the fins are barely attached and feel like they will fall off. But as long as I dont blow another pump 250 miles from civilization I'll be good
they hold more and are aluminum so they get rid of heat quicker than plastic. the other plus is the baffling inside doesnt let the fluid captivate and foam which is a big issue as well. with that said the fluid gets very hot even with the added aux cooler. so the more u can keep the fluid temp down the better
