Don't give me that look
Ok this is my current plan. What was your experience installing the Lokar tube? Did you have any trouble getting it to seat properly in the block? Any tips or advice for getting it seated? It has held up to the heat OK?I went with the Lokar one, totally happy with it.
It isn't made for the 6.2L but the one that is mentioned in the thread fits our application no problem. You just have to buy a longer dipstick and cut it to length. View attachment 423414
Well my experience will be a little different since we have a lift at work. But to answer you question, no. I was able to see the hole and made sure the Lokar dipstick was fully seated. The biggest pain was getting the old tube out. Once that was out, smooth sailing after that.Ok this is my current plan. What was your experience installing the Lokar tube? Did you have any trouble getting it to seat properly in the block? Any tips or advice for getting it seated? It has held up to the heat OK?
What lokar tube did you use? Do you have a link or model # for the one that will fit a 6.2?Well my experience will be a little different since we have a lift at work. But to answer you question, no. I was able to see the hole and made sure the Lokar dipstick was fully seated. The biggest pain was getting the old tube out. Once that was out, smooth sailing after that.
