Sunroof drain tube
JLW2
St Augustine
I have seen where the sunroof drain tube ends at the bottom of the cab and it eventually rusts through. I can’t believe Ford would do something so stupid. I have been looking under my gen 1 for the drain tubes and can not find them. My cab seals and the areas around them look essentially new ( 2014 truck) with original spray coating over them. No tunes sticking through any of them. There is only a little surface rust under the cab behind the front wheels - smooth, like the paint worn off on both sides. It does not appear bubbly or badly rusted - encapsulating to protect it I still expect the bottom of the cab to rust out over time from what I read
I would do what I could to prevent this if I knew where these drains actually were. Any help appreciated- photos to shown the location - references to locate
MurderedOutSVT
Brodozin
The ATL
Actual locations of the drain tubes at the bottom of the cab, photos or what anyone has done to correct or protect
Oh...I dont know that. I reamed mine out with string trimmer line and it drains now. The drains lines start at the top fron left and right corners of the sunroof
