Power loss after running
Skubik
Ah that makes sense.
Is there a chance it is defective or maybe something came undone or loose? You're definitely on the right path with the boost leak imo
F
firemanjoe
Apple Valley, CA
The problem started before I replaced the valve. That’s why I replaced it. I’m not sure it has to do with a boost leak. When it does it, it still builds boost and vents, but feels like the turbos aren’t working
nikhsub1
Los Angeles
I had this happen to me once. Boost was being made and registering on the dash, but there was very little power. My only thought was that the BOV got stuck open.
which on the surface seems to rule it out but ...
NEVER modify a truck with a known problem or issue ! ! ! !
Your troubleshooting becomes exponentially more complicated the more mods you take on.
Skubik
Now that I think about it My son had the same issue on his ford focus st. It was the plastic pipe intercooler piping that came loose. Check all intercooler piping and make sure the clamps are tight. If the problem was there prior to replacing the BoV chances are it's an intercooler pipe that's loose.
F
firemanjoe
Apple Valley, CA
I don’t think it’s innercooler piping because they seemed okay when I removed the innercooler for the BOV but I’ll check them again.
Skubik
it's just weird man, are there any codes?
I just can't imagine it's the turbos but you never know. Also sounds like when your catalytic converter is clogged but I can't imagine it could be that already. Gotta be something dumb. Have you tried doing the throttle reset? Not sure it would help but there's a trick on YouTube where you turn the key on, push the gas pedal down slowly and release quickly 5 times etc..and most people reported it helped their performance, response acceleration etc..
It's a long shot but who knows.
You're using 93 octane correct? I know people say todays turbo vehicles run fine with 87 octane blah blah but I just don't agree, if they do it not for long and you're not helping the engine. Anyway I'm sorry I can't be more help here :/
95,856
59,548
twentyfour
Latest posts
