GEN 2 Loss of power
C
c_phillips02
Truck is pulling timing bad. Watch the spark knock in the video. Truck is backing the throttle down to 50% when WOT. Have zero misfires and can’t hear any pinging. Fresh plugs, air filter and run 93 octane. Could I be getting false knock?
thatJeepguy
GA
I hear a blowoff valve or a boost leak at the end.
thatJeepguy
GA
It has a VTA BOV adapter. I took it off to make sure it wasn’t the problem but no change so I put it back on.
Why do you need a bov adaptor?
I bet you have a boost leak and the truck is pulling time and fuel because its not getting the air it wants vs throttle angle etc.
C
c_phillips02
I don’t need it. It is just for sound.
The ECU is seeing knock according to the spark knock #’s. I do not hear any knocking or pinging. When it runs good the spark knock is showing 0 to -3 and has plenty of power. I’m leaning towards it seeing false knock or a knock sensor is bad now.
