Let me get this right the white power wire from the light still goes to the battery and black ground wire straight to the pin switch since it will be ground to the chassis when mounted in place. When you open the hood it fully open completing the ciruit. Is that right?
Why not just use the hood switch already in the truck?
Going to answer my own question, because the hood switch is only found in trucks with remote start. On a 2012 it is a push pin type switch, not a mercury type.
here is my switch mounted, you can bend the mount so it only comes on high angles
