Poor Man's 700 Lumen LED Under Hood Light
infinitereality
infinitereality
SLC IR/8
Louisiana
Java
MI
put a mercury switch on it and you will like it even better.
Blind1
Central Alabama
I'm still not grasping how the mercury switch works. I'm assuming it works like the switch in this refrigerator. I need a better explanation of one to understand it. I'm going to do this mod one way or the other. I guess I need to start googling. ;)
Java
MI
Would that mean it would come on when you jump it?? :confused:
Yukon Joe
Buffalo Run Support Raptor
RPG and WSI present The South Dakota Buffalo Run - FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor
I've had one for more than a year. I guess it could come on with bouncing around. I don't care too much. LED lights have a zillion hours on them and then bounce around time is only a percentage of road time. A go pro would answer the question. There is already a mercury switch on my truck for the remote start so you can't remotely start the truck with the hood open.
I was thinking you could just as easily set up a pin switch instead.
infinitereality
infinitereality
SLC IR/8
Louisiana
Ordered a mercury switch for another project, $7.50 shipped. I may get a 2nd one once this one comes in, depending on size. Wiring will be a cake walk, just hook in line with the negative wire.
dataustin
Blind, I assume that the mercury switch would close the circuit when the hood is raised to a certain angle.
Blind1
Central Alabama
Yea Dataustin, I did end up googling it to find out how it works, but I'm leary about it being stuck in the on position when parked on a incline and off-roading with one.
I'm definitely interested in how Infinitereality is going toninstall one to prevent it from coming on when not needed.
I received the light other day, now I'm waiting on the waterproof rocker switch with inline fuse holder to show up. I will end up having right at $60 invested in it once done.
