Picking up my Gen 1 tomorrow!
EricM
OHIO
ah ok, so fuse 27 relocation is the same issue?
those look great, easy swap i would think?
Just pry out the old ones and install those. I wired it from the puddle lamp hole. There a slight trick to getting the puddle lamps out, but I'd done that before.
I grabbed the turn signal +12V using a Posi-Tap on the rear facing signal wire, and wrapped the ground wire around the puddle lamp ground lug before I plugged the puddle lamps back in.
