shootermcgavin
care to share details on what leds inside/out you replaced and what with?Ok update
- I have the Pedal Commander too -
- Fuse 27 relocation (A must do) - Done
- JLT or similar Oil Separator - Done
- Replace all interior and exterior bulbs with LEDs - Done
- Front and rear cameras with Power Magic Pro or similar -
- Line-X Bed Liner and/or Bedrug / Bed mat - Done
- When needed: Odyssey 65-PC1750T Battery, watch for sales.
- Bed cover: ReTrax Pro MX; Back-Flip, etc. - Done
- Geiser springs up front, (mid-perch depending if you want the front higher) - Did mid perch still debating the Geiser
- Deaver Leafs Springs or similar in rear - Done I did Deaver +1 to level her out a bit
- Camburg or similar shackles to replace OEMs - Dang did not do this... Ugh
- Bump Stops (when replacing the leafs) I just did the Bump Pads, but sounds like I need to do upgrade them as well?
