Phoenix Android Audio retains Sync 3
GCATX
King Dingaling
Central Texas
Console does need to be closed for sound from the tablet to come thru.
Do this. Close the console. Open the blue tooth menu. Connect your phone via blue tooth and stream. See if you get sound.
Then try to stream something on the tablet. Still no sound?
Thanks, how do you properly "close" the console? I have closed it with all the other apps with the upper right "windows" button, but the Sync XM music keeps playing. Is this what you mean, or something else?
Kona754
Yuba City CA
Kona,
You hit the nail on the head. This radio is for a tech nerd. This is not a simple “ plug and play and it just works” like a well refined android phone or apple product.
The install looks easy, but the connectors are finicky and DELICATE. The software is a little quirky out of the box. There are certain little buggy type things that you have to work around.
A few examples.... the screen refresh and hardware overlay smooth out the visuals are performance. There is no manual for it. I found it online on a forum.
The blue tooth on the unit is just average quality for cell phone use. So I use sync for that and don’t bother to connect my phone via blue tooth to the unit. I’ve found the implementation of Bluetooth sync is actually very good and phone calls seamlessly pop right up no matter what you’re doing.
I stream direct from the unit and that works great. Waze navigation works perfectly and is full screen. You can listen to your sync 3 radio or stream your favorite service right on top of it split screen. The downside is that if you are using sync, you won’t get the Waze audio/voice prompts. Low level annoyance.
All the controls for HVAC and such work as you’d expect. YouTube works. Other apps like Ring doorbell, garage door openers, Etc.... all work. Email works. Web works.
I haven’t used android in years, but I was at one point very fluent with the os. I was able to knock most of the rust off at this point...
My advice to anyone considering the unit.... don’t buy it if you’re not a tech person — you’ll get frustrated. Don’t buy it if you are OCD about everything working exactly the way you’d intuitively expect it to work. See above quirks. Don’t buy it if having unused quick launch icons bothers you. There are features and cable connections you probably won’t use for things like additional cameras and audio video outputs.
If you have an average to above average skill set with tech, enjoy working through android quirks, like new gadgets, and hate the current look of your interior... this thing is AWESOME.
Will a novice get into your truck and find things that don’t make sense on the new tablet? Yes. Will they not know how to open sync? Maybe. Will they get flustered because to use sync and Waze together.... first you have to open sync... then you have to open Waze. Then to change stations you have to use the steering wheel controls. Going back to sync screen will cancel your Waze navigation. Would that drive some people nuts? Maybe? But I know the unit and the truck inside and out. It’s not a big deal to me.
Does that make sense? It’s completely worth the money spent and I love the product but you have to know how to use it. I could sit you in my truck, do a demo of it... not miss a beat.... and make it look absolutely perfect, simple, flawless in operation.... without you ever knowing there are software quirks... because there are work arounds to all of them.
If I then tell you to play with the radio, without ever using it before.... you’re going to stumble into quirks and get frustrated, say it’s garbage, and tell me to throw it away.
If only you lived near me. I'd make the drive and pay you for the in person run down just to feel clarity and then I'd buy it. Thanks for all the detail. It's been a huge help in which direction to go
G
Guy
That music shouldn’t continue to play. Something is amiss.
There is a connector that connects to the back of the tablet. It’s a white connector. It connects towards the top of the unit below the top camera button(s) et al. It’s a very tight connector. Pull it out and firmly press it back in place along with all those connectors up top there. It takes a little bit for it to “click” in place.
Also make sure your canbus connector to the red box is firmly seated and that everything is connected as per the YouTube video. I believe your issue is that the tablet audio isn’t connected via the pigtails to And so all you are getting is sync audio.
Herkguy
Little Rock
Okay, I plugged in Both GPS antennae, now SYNC GPS works.
Still no sound from the tablet. I pulled apart and snapped back in the "T" connectors behind the CD player. I am still not getting any sound out of Phoenix apps, whatever is on the factory stereo is still coming through the truck speakers while Youtube is playing on the Phoenix.
Anything else I should check while it's out?
Thanks.
I had this problem. To fix try making a phone call with your phone bluetoothed to the sync system. It should pull up your sync and the phone call. Hangup, then try and go back to youtube and see if it works. I’ve had mine get stuck like that and a phone call snapped it back to normal ops.
If that doesn’t work try reflashing the canbus via previous instructions.
nikhsub1
Los Angeles
A
Cool story bro - I’ll stop asking questions to try and help you troubleshoot. You clearly know how shit works rofl
Actually, I do. But to answer your question, the default map in sync is ***** so it is definitely the OEM GPS being weird. It has me going in the opposite direction most times and it takes forever to recalculate.
